I am a relatively new owner of a 2023 RAV4 Prime SE. We took our first 1 hour+ trip on Sunday and after 1 1/2 hours in hybrid mode the air in the car was had an odor like the Canadian wildfire smoke, I then discovered that the Recirculate button was On. I was certain that I had turned Recirculate Off the last time I used the car, so I stopped and restarted the car. Sure enough, the Recirculate button came On. There was no odor in the fresh air, so the odor was coming from the car.
I checked the Owner's Manual and from that it seems as if the car is designed so that the Recirculate function will be activated each time the car is started, at least in the summer.
In my opinion, this is a dangerous design choice. No one should drive a gasoline powered car for extended periods of time with the air set to recirculate. So automatic Recirculate may be OK when in EV mode but definitely not in Hybrid mode.
is there any way I can change the behavior of the Recirculate button?
