I'm probably a small minority of enthusiasts that is lowering my RAV4 and Prime at that.
It's been challenging finding a good set-up that works for the Prime given it's over 500 lbs heavier than the Hybrid.
I posted a while back that i went with the RSR springs initially but the springs with factory shocks was too soft and felt like a boat plus i couldn't get it to lower more.
We found that the Harrier Hybrid in Japan has the closest set-up although 440 lbs (200 kg) lighter than the Prime.
We special ordered the coilover and installation was spot on no mods.
We lowered it more to about 1 inch (2 finger gap)
With the 16 way dampening the ride is so much better now but still soft enough for a CUV.
When i had originally did my alignment on the RSR i had -1.7 and -2.0 degree of camber in the rear so i installed the Cusco rear adjustable arm kit and did my alignment recently now pulling it back in to about -1.4 degree of camber after lowering my car another 1.5 inches.
There's been some folks asking so i thought i'd post what i have.
next up looking to see if the Hybrid Exhausts will work on the Prime.
RSR Springs Front: 3.16kg/mm Rear: 4.39kg/mm
Tein Flex Z coilovers: Front: 6 kg/mm Rear: 6 kg/mm
Part# VSAAG-C1AS3
Price: MSRP is $1,390 special order through authorized Tein dealers
Cusco Adjustable rear upper arm set
Material : High Strength Steel
Product Number1A1 474 L
MSRP$614.00
JAN Code4996338024329
Note : Rear camber adjustment range from +15mm to -8mm.
cuscousainc.com
Part# VSAAG-C1AS3
MSRP$614.00
CUSCO Products List for 2019+ TOYOTA RAV4 (XA5) | CUSCO USA Inc.
Coilovers / Suspension / Drive Train / LSD / Rollcages. Used by professionals around the world in motorsports, rally/circuit racing, gymkhana and autocross.
