Hi all, as the thread title suggests, I have a 2017 Rav4 Hybrid Limited edition that seems to be experiencing parasitic power drain that is killing my battery.
Background: in the last few weeks my battery has died if the Rav has sat for more than a couple of days. I've boosted it, it seems to charge while driving as it will be good, no power issues unless it sits again for a few days.
Thought it was the battery as it's about that age, but I took it to the local shop to get it checked out and they found that the Rav has a 130-140 milliamp drain on it once everything has shut down. They finally found that, if they pull the 10A fuse for the Steering Lock ECU, the power drain drops to a reasonable, if maybe even low 30 milliamps, so they think that is where the problem lies. There are no warning lights on the dash except when the battery doesn't have enough power to start the engine.
So my question is: has anyone else had this issue and if so, did you find a solution to it?
