1 - 13 of 13 Posts
If rubber insert fits - it's a perfect solution.
My previous experience with rubber inserts was kind of strange: I've bought brand new car from dealer and when later asked dealer to replace inserts was told - car has non compatible wiper blades.
Strange, but it happens with two cars 2007 Camry and 2017 Camry bought new from dealer. One thing was common for them - both made in Kentucky.
So I've start using Michelin blades from Costco - just trowing them away when worn out.
Oh, that's weird. You can always buy the oem wipers too just once then refill them with inserts every time after that
I have the Rain-X Truck & SUV Wipers. They worked exceptionally well during a snow storm with significant ice buildup on the windshield. But expensive and probably not worth the money unless you drive consistently in very bad conditions.
OEM refills work great. Be interesting on seeing how Michelin and Bosch work out. I know with a newer vehicle OEM works well.
My old tank (2011 Sienna) has tons of KM 340,000KM and original windshield. It is pitted but no cracks. I use RainX on it and it helps a lot. Fills in the little pits etc clears ok.
The local wallyworld usually has michelin and rainx wipers. So, I'll pick from them as needed. I use beam wipers and lean toward silicone when available. The weather and dusty air here destroys wipers pretty quickly. I never get more than a year out of any brand.
With Toyotas past history of screwing US consumers out of quality refills, I'll skip the dealer and Toyota. Nothing like 2-3 different PN refills for a couple of my previous Toyotas, with US consumers getting the squeaky streakers, and having to selective order the 'better' OE refills from clueless clowns at the parts department. So, to hell with the rubber inserts!
1 - 13 of 13 Posts
