I did brakes today, so had to get the e-brake units into maintenance mode.
I followed the posts that show 3 pulls, 3 pushes, then hold on push. Did not work for me.
2020 Lim gas.
Here's how mine work.
No foot on brake, turn or press ignition to "ON", one past "accessory".
Foot on brake push the ebrake button once to release the ebrake
Turn off the vehicle, no foot on brake go back to "ON", one past "accessory"
Pull ebrake button 3x, push button 3x, then push-hold button, then step on and off the brake
That last bold step was needed for the e-brake units to move into maintenance mode.
Turn off vehicle, do your work. When done, pump the brake pedal to push some fluid in to tighten up the calipers, Start vehicle, pump some more, then operate the e-brake (pull) and it will go back into position and remove from maintenance mode. From there it should be good to use normally.
2020 Lim gas.
