I had to tie down the hatchback because I was transporting large items. Is there a way to stop the annoying beeps, because the hatchback is slightly open?
It is said in this post that the beeping will be silenced when the PBD (Power Back Door) is turned off in Vehicle Settings. I have not tried it.I had to tie down the hatchback because I was transporting large items. Is there a way to stop the annoying beeps, because the hatchback is slightly open?
I went to my car to explore options. I opened the powered back door part way using the button on the hatch. I started the car -- display showed the rear door open. I went to the settings menu and was able to toggle the PBD to the off setting, as shown blurrily below. This is a 2023 -- not sure what's different in your car.i turned off the PBD under the Vehicle Settings. The door won't open using the button on the bottom left of the steering wheel or by pressing the door open button on the remote. If the door is open I can't access the Vehicle settings to turn off the PBD
There are scads of forum discussions on where/how to do TechStream. And what we're usually referring to running at home starts with a Mini VCI J2534 cable that connects your laptop's USB to the car's OBDII port. Then installing some form of unofficial TechStream software. There are several vendors offering this at Amazon, but the software versions vary, V16, V17, V18. We should use V18.00.008 (or newer) as it recognizes the RAV4 Prime. This is not the friendliest way to go, which is why Carista is popular, can run on a phone, but costs more.TechStream sounds really good. Do I install it on my iPhone or laptop? If it's on the laptop do I have to be very close to the car for it to work? Where do I find the installation instructions? Of course any tips to get to that screen you had displayed would be great.
The MMI screen where you see radio and navigation has its own settings menu, totally different stuff.I have a 2023 Rav4 Prime and did notice a customization screen in the settings in the center monitor display not the dashboard.. Would that do the same thing?
Yes, same here. So neither the MID settings nor the TechStream settings made any difference in silencing the warning beeper.turned off the PBD, unfortunately I still got the beeping sound.
Nothing constructive to add, other than I still remember an IKEA run in the Prius back in 2012. Box too big to close the hatch and I had to listen to that damn beeper for 4 hours.Yes, same here. So neither the MID settings nor the TechStream settings made any difference in silencing the warning beeper.
Very sorry for the fruitless wild-goose chase.
I believe there is a sensor/switch on the latch.How does the RAV4 detect that the rear door is open or closed? Is there a position sensor? Does it know whether the latch is open/closed?
Yes, I have seen that mentioned on older Toyotas, so if that's the case, maybe finding a way to either close the switch or ground the wire (temporarily -- only while moving a load) would silence the alarm.I believe there is a sensor/switch on the latch.
