Can I use an 220v extension cord to use the 220v dryer plug for charging my RAV4 PHEV?
The adapter I was linking to was the one that has a single 14-50 (240v) plug. And, yes, any person that uses such an adapter should take careful measures so that it is not used for any devices other than the car charging cable.Um ... Wow. I hate to see these products linked in a forum like this. You never know the condition of the house electrical system and what the results could be.
I am not an electrician. But have learned over the years that whatever can go wrong generally will go wrong in time.
1. The adapter for normal 240V dryer, welder, air conditioner, etc. : This will work but is it worth $70 to buy an adapter that will allow any 120V device to be plugged into a 220V circuit? I know "you" know better but what about that kid you hire to look after the dog/cat/house while you are on vacation? Isn't it worth paying a bit more to buy a 30A EVSE that charges faster and doesn't carry the same risks? If you must do this please get a lock or at least tape the adapter to your EVSE to make it harder to misuse.2. The adapter with two 120V plugs: Really? Are you actually going pay $70 to run extension cords around the house into two opposite pole outlets to charge your car in 1/2 the time? Just don't do it.I find all kinds of innovative ways to use products in different ways to save money. But not if it compromises the safety of others.
I have no argument with your posts, Templeton. Nor do I judge those who charge in this manner. I just thought there should be some awareness to the risks raised once the link was provided since this link had none to date. You never know who might see this one thread, take the suggestion, and not research any further.The adapter I was linking to was the one that has a single 14-50 (240v) plug. And, yes, any person that uses such an adapter should take careful measures so that it is not used for any devices other than the car charging cable.
I do know that many many prius phev users have successfully used such adapters in the usa. And pretty much all prius phev and rav4 phevs in europe are by default using their toyota cables with voltages in excess of 200v.
Sure, I think that if one reads anything on the interwebs, it is always important to verify every single thing that one reads. And, yes, one should not use any electrical adapters in any application unless one knows exactly what one is doing. And, as always, every action is always taken at one's own risk.I have no argument with your posts, Templeton. Nor do I judge those who charge in this manner. I just thought there should be some awareness to the risks raised once the link was provided since this link had none to date. You never know who might see this one thread, take the suggestion, and not research any further.
Ha, so the answer is yes and no.Can I use an 220v extension cord to use the 220v dryer plug for charging my RAV4 PHEV?
The 2022 on R4P has an internal 6.6KW charger. I see 7.2-3KW on my 240V cord. I believe that is too much load for a 120v based cord. the prius and old Rav4P did not exceed 3.3 kw charging internally, so a 20 amp 120v dedicated circuit was ok.The adapter I was linking to was the one that has a single 14-50 (240v) plug. And, yes, any person that uses such an adapter should take careful measures so that it is not used for any devices other than the car charging cable.
Just so you understand, the amps don't change when charging on 240v, just the voltage.The 2022 on R4P has an internal 6.6KW charger. I see 7.2-3KW on my 240V cord. I believe that is too much load for a 120v based cord. the prius and old Rav4P did not exceed 3.3 kw charging internally, so a 20 amp 120v dedicated circuit was ok.
if the poster can afford a R4P he should play it safe and Do what is recommended. I am also told that the dryer outlet is not rated for the duration and load of EV charging.
Greg- I've been a draftsman, an engineering technician, and a land survey tech (LSIT). 14 years in the nuclear power industry (1974-1988), the rest with CalTrans (1988-2013). I'm not a licensed engineer, but I've absorbed a lot of knowledge on the job, you might say. I could probably have passed the EIT if I had decided to go that route and studied for it. I did pass the LSIT, on the first attempt, an achievement I take quite a bit of pride in. And the 4 other people in our little study group all passed on their first attempt, as well, so the time we spent studying and doing practice exams was well spent. Most of my experience as an engineering tech and draftsman for those first 14 years was in mechanical (piping system static and seismic analysis), with some electrical. After I got in with CalTrans, it was all civil engineering work: highway bridges, retaining walls, and drainage structures, and the last 7 years on a land survey crew with CalTrans District 10 out of Stockton. As a survey tech, I added construction survey staking, digital terrain mapping, and some property boundary and right-of-way work. I almost got my professional land surveyor license: passed the National Principles of Surveying exam, but couldn't quite pass the State Specific in two attempts. If it had been a 6 hour exam instead of only 4 hours, I could have easily passed. I had the knowledge, but what killed me was the construction and photogrammetry problems: these are math-intensive, take at least 10 minutes each to solve, and I just ran out of time, and failed to accumulate enough "points" on those two sections of the exam to pass it. When I took the PLS exam the second time, in April 2015, I was already retired, and realized that the chances of me ever really wanting to go back to work as a land surveyor were pretty much zero, so I gave it up. BPELSG was charging $600 a pop to apply for the PLS and PE exams at that time, and I realized that was too much money to just get a piece of paper to frame and hang on the wall.I made my own 50a cables, just bought the heavy duty wire, and screwed the connectors on.... I prefer plugs and sockets I can open and visually inspect (and tighten every so often, like the maintenance you should do on your electric panel).
By the way, my home was built in December 1997, and is in Southern California, and has the 3 blade 220v connector, so perhaps your statement about being banned in 1996 is off by a couple of years, perhaps plans APPROVED after 1996 is what happened...
I had a second "dryer" circuit put in my garage near the garage door, was for a 220v compressor, but now plug the level 2 charger into it... am changing to 4 pin connector, since I bought a second level 2 charger that came with that plug. My first charger was a kit, and I added the power cable and plug myself.
If your wires get warm, you should consider a larger gauge, but the voltage drop really comes in the plug and socket. After 10 years of plugging and unplugging (switching between compressor and charger) these need replacing... that's good enough for me.
(by the way "charlot", you MUST be an engineer, right?)
Greg (also engineer)
The catch with using an existing 220 volt outlet is that that it may not be able to supply enough current. My girlfriend and I have two houses. We had the electrician install a 50 amp 220 volt line in the house where we just have a one car garage. But we had him put in 100 amp line to support two level 2 chargers in our house where we have a three-car garage.I sometimes wonder why EVs do not have an onboard Level 2 EVSE as standard.
But you can always buy a portable EVSE for a couple of hundreds of dollars and a bunch of adapters so you can plug into almost anything you may find, like outlets for RV power supply, clothes drier, electric range etc.
An actual level 2 charger plugged into 220 volts with adequate current will charge my RAV4 Prime completely in 2 and 1/2 hours.Most of the USA is 120/240.
The prius and R4R Primes are designed for world use.
They work on all currents and 50 and 60 hrz.
My Primes charge at 12 -15 amps 240 with the stock charger. Prius Prime changes in 2 hours on the stock charger on 240 volts. The stock charger on the R4P on 240 volts takes about 5 hours.
Connected to a 14-50 Dryer plug.
Interesting. When I have tested my 2023 SE with the stock cable at 240v, it charges in about 4.5 hours.I have A 2021 SE so my full charge time on a 220V L2 EVSE is 4-1/2 hours (actually finishes in about 4h10m).
I was surprised to learn that using the stock EVSE with 220V supply only cut my charge time from 12h to about 6h until I learned the stock EVSE is current limited.
6.6 kwI haven't kept up with the later model charge systems - do you have a 3.3kW OR 6.6Kw charger?
My house only has 125 amp service. The larger 2 story houses in our subdivision have 200 amp, but the single-story models like mine only have 125. I've been told that there's no way to increase this unless the power company installs a larger transformer on our block, which they're not going to do for just 1 homeowner. The electrician I was talking to about this told me that families with 2 EV's often face a problem: their electrical service may only have enough reserve capacity to support "one" Level 2 EVSE at 32 amps, so if you have two EV's, and need to charge them both at the same time (typically overnight), each one can only charge at 16 amps. Then there's the issue of cost. To increase my home service to 200 amps, assuming the transformer would support it, I'd have to run a new, heavier gauge cable, about 350 feet from the transformer to my house, and since utilities in our neighborhood are all underground, doing this would likely require digging a trench to lay the cable. And I'd need a new breaker panel and a new meter. The cost for all of this would probably run north of $35,000, according to the electrician, and more than likely, it simply couldn't be done. This is a disadvantage of having underground electric service compared to hanging the power lines from poles: there's no easy way to upgrade the equipment and wiring.The catch with using an existing 220 volt outlet is that that it may not be able to supply enough current. My girlfriend and I have two houses. We had the electrician install a 50 amp 220 volt line in the house where we just have a one car garage. But we had him put in 100 amp line to support two level 2 chargers in our house where we have a three-car garage.
These are all valid considerations, but my [rhetoric] question was about EVs having an onboard EVSE . From the point of view of overloading or not overloaded the circuit it doesn't make any difference if the EVSE is portable, or mounted on the wall, or integrated into the car. In the case of the RAV4 Prime it's going to draw up to 30 amps @ 220VAC ... a little less if the voltage is higher.The catch with using an existing 220 volt outlet is that that it may not be able to supply enough current. My girlfriend and I have two houses. We had the electrician install a 50 amp 220 volt line in the house where we just have a one car garage. But we had him put in 100 amp line to support two level 2 chargers in our house where we have a three-car garage.
When a car charges at 6.6 kw vs 1.3 or 3.3 there is obviously more flow. more flow makes me think more heat. more heat destroys the washer outlet and wires (As it is not designed for heavy loads and long duty cycles). when wire casing fails due to heat it cracks off or catches fire. FIRE BAD!Just so you understand, the amps don't change when charging on 240v, just the voltage.
