What grade of motor oil is suitable for the Rav, I been told 5w.30 is good for Toyota engines......Your thoughts please
Yes I can but it wouldn`t be Mobil 1 anymore rite ? I would like to continue using Mobil 1 to see if the car`s performance improves as it`s only been 3 months since I started.Brother said:ow40 would be better. Can you get a non synthetic 10w30 or 5w30?
Yeah I had no idea either what the numbers meant so was very happy to read that comment explaining it. Just makes it so much easier when we can actually understand for ourselves. Also, you have a choice, you don't have to buy from the shops...you can get it from Amazon, ebay, walmart etc online and can either pick it up from the store or have it delivered to your door.Engine oil
Actually I didn`t understand what the numbers &w
alphabet means. Thanks for clarifying. The Mobil shops here don`t seem to carry 5 or 10 w 30....the only ones I see here are 10 w 40 or 5 w 50 i think. So In have no choice but to purchase those. The extra weight shouldn`t be a problem rite ?
Midas has been doing my oil changes for years but Rav's just seeming to get more sluggish and it's bothering the crap out of me. I've just left them alone on some other stuff (claiming to do an alignment and they never did smh) so I'm trying to figure out how to get her back to her glory ya know. I've been reading and ppl/Toyota recommend the 5W30 but I've read the synthetic oil can leak easier since it's not thick enough but that they also have the high mileage (I'm at about 126K now) that's supposed to protect and get better mpg etc but that the conventional oil's got a lot of junk in it. So, I'm wondering if a synthetic high mileage blend would be good. What do yall think?I have used 10W30 but gas mileage seems to go down, and car feels a little sluggish, may just be the cheap oil i'm using. :lol:
Stick with 5W-30, especially if you live in a place where it snows or at least gets close to 32F
yup the synthetic 5/30 is the way i role here.Sorry if this comes across as arrogant, forgive me for being dutch. I have a mechanical engineering background and have had a fair bit to do with hydrodynamic engineering which essentially is what oil flow and pressure is all about. Folks please take this seriously if you wish to look after your RAV4, use ONLY and ALWAYS manufacturers specific oil requirements in viscosity and type and always service to log book intervals. Using a different viscosity can seriously affect the longevity of your engine, gearbox or drivetrain. The oil has 3 purposes: Primarily for cooling, secondly for providing hydrodynamic separation (pressure) and thirdly for boundary protection (lubricity).
So if for instance you would put a thicker viscosity oil in the results would be: more load on your oil pump due to higher flow resistance and slower flow throughout the engine and therefore not whisking away the heat that is needed. The engine would run hotter and hotter means softer metal parts so speeding up wear. Many will say that a thicker oil increases oil pressure, they are right when it comes to pressure at the gauge, which measures it at the pump, but this does not show the pressure drop at the end of the oil galleries where it has dropped significantly more due to the decreased flow rate.
The decreased flow rate also affect the hydrodynamic layer of oil on bearing journals where reduced flow rate and pressure will allow metal to metal contact and test the boundary layer to extremes.
So please folks, for the sake of our engines do the right thing, run the oil that the engine has been engineered for.
I just saw something saying to use 5W20 for less than 75,000 miles, and 5W30 for over 75,000 miles on my 2008 Rav4 3.5l. I didn't see who the source of that information was, but that's a new one to me. I guess I can see the idea behind it, but I've never heard that before. There's not a huge difference between the 2 anyway. Anyone have thoughts on this?What grade of motor oil is suitable for the Rav, I been told 5w.30 is good for Toyota engines......Your thoughts please
