🚗 Whole package of LED Light Bulbs for 2013 2014 2015 Toyota Rav4
1299 Views 0 Replies 1 Participant Last post by  Valli AUXITO
5
With top-quality LED bulb upgrades for Toyota RAV4 available on Auxito, you now have the option to improve the stock lighting of your 2013-2015 Toyota RAV4.
All the LED bulbs plug and play, without any modification. You can choose a whole set of LED bulbs or choose the required parts to upgrade the lighting.
LED Bulbs replacement model & technical specifications
Package Included:
  • 2 Y13 Series 9005 led headlight bulbs (Low beam)
  • 2 I9 Series H11 led fog light bulbs (Fog light)
  • 2 7443 Amber & White (Front Turn Signal Lights)
  • 2 7440 Amber (Rear Turn Signal Lights)
  • 2 T15 White (Back up Lights)
  • 6 T10 White (Map/Vanity Mirror/License Plate Lights( 3*2pcs/set))
  • 2 31mm White (Dome Lights)
LED Headlight Bulbs High & Low Beam 9005:
  • Upgraded Independent Drivers, 50,000hrs Long-lasting
  • Y13 series-the Brightest led headlight bulbs of AUXITO
  • 40W/bulb High Output, 8000LM/bulb High Brightness
  • 360-Degree illumination, Perfect Beam Pattern
  • CAN-BUS Error-free, Plug & Play Installation
  • 1,2000RPM Turbo Cooling Fan
  • LMP Chip - Newer Technology than CSP
Fog Light Bulbs H11:
  • 2000lm/bulb, 4000lm/set
  • 3000K Golden Yellow
  • 1:1 same light filament position
Front Turn Signal Lights 7443:
  • DC9-18V, 1600LM/PC, Amber yellow/white
  • Dual-color function: The switchback turn signal flashes 'amber-off-amber-off' instead of 'amber-white-amber-white', much easier to be seen. Fit for dual filament socket. They will light up with white color as the low-filament running light/parking light, and switch to bright amber any time when you hit the turn signal.
Rear Turn Signal Lights 7440:
  • Power: 24W
  • Voltage: DC12-24V
  • Light Color: 1500K Amber
Back-Up Light Bulb 921/912:
  • Color: 6000K White
  • Lumen: 2600lm/Pair
  • Working Voltage: DC12V
  • Working Power: 5.5W
  • Current: 0.45A
Map Vanity Mirror License Plate Light Bulbs T10/194:
  • Voltage:12V
  • Color: 6000K bright white
  • Power:2W/PC
  • Lumen:240LM/PC
Dome Light Bulbs 31mm:
  • 10-24V DC, (under 12v: 0.2A,Power:2.5W/PC),
  • 6000K xenon white
  • 0.63 inches in width, 1.25 inches in length
1 - 1 of 1 Posts
1 - 1 of 1 Posts
