I have a question regarding my 01 manual transmission RAV4 250K miles. After I travel to my destination, if the car doesn't sit for at least an hour , it is very difficult to restart. It has never left me stranded, but I have to crank it repeatedly for a couple minutes. Once it is restarted it seems to run ok. Also the car has NO passing power. When I do give it gas to pass it lags for at least a minute before the car begins to accelerate. Plus I usually have to feather the gas pedal before moving from a dead stop. My guess is something withe the ignition system, but any info would help. Thanks
There's a million reasons, but start with the obvious. Have the battery tested, and also get your car scanned at a local autozone or equivalent (free code check). You could have a failing ignition coil w/o it throwing an engine light (I know because I've been there), but again start with your battery. At 250k miles, when were your spark plugs done last? Just curious.
Thanks for the reply. The battery is good and fairly new. I can crank the ignition on and off for about 2 to 3 minutes and it will finally turn over. I changed the plugs about 2 years ago. I have also changed the ignition coils in the past with ones I got off amazon. Wasn't 100% sure they were genuine. Those could be the culprit.
