1 - 2 of 2 Posts
I have a 2001 rav4 2.0 4x4 automatic and it has 114,000 kms on it. I recently changed the engine oil, oil filter, fuel filter and spark plugs last year. I'mm aware that I haven't replaced the ATF of the transmission and trans axle oil for front and back. But I'm certain it has an engine problem not a transmission problem because while it's on Park and I step on the gas pedal, it revs sluggish. Evermore, when the car's in motion and going uphill whether the A/Cs turned on or off, it runs slower than a 1300cc car. But I noticed when I warm up the car and try to drive it right away, it runs well for a while but when it has reached it's running temp. then the nightmare starts.
Any suggestions what to check or clean?
By the away, a local shop here tried to re solder the cars ECU and adding another fuel pump which I don't know how they did it. Problem's still there.
1 - 2 of 2 Posts
