I have to 13 or so step process to disable each time i want to drive away, but i'm thinking that i may just pull the fuse for the stupid traction control/abs and be done with it. If all it means is that i have old school braking instead of abs, i am fine with that, that's what i learned to drive on anyway!! Thoughts?
You could pull the fuse and then do some trial driving in an area with no traffic or other dangers.
Yes, you can pull the fuse and go back to the old days. You will lose ABS, VSC, Traction Control, DAC, HAC (if equipped), as well as cruise control.
According to the schematic i found online, id also lose the radio and all the gauges, god they make this difficult!!
