If I get into mud or deep snow the 4wd light will come on in a mile or less. The 4WD light is the only one on.
When this happens the accelerator will also start to be overridden and the engine won't rev above idle. This is obviously bad as it leaves me stranded idling. Oddly enough I have found reverse still works in a pinch. Usually though if I sit and idle for a minute it will come out of it.
Other than your other post you linked to we had another discussion of the issue. The conclusion was the 4WD light comes on because the system is overheating and in danger of damaging itself. That's why it works again after a "rest period."
The permanent solution is use a vehicle with a more robust 4WD system. An F-250 In 4X4 LOW would do nicely.
Well that is a disappointing answer. So a little front wheel drive car is more capable than an AWD Rav? This is just driving down a gravel road to my house when the conditions are crappy, which is any time it rains more than .25" in the rural midwest. The other conditions in snow were on a slushy highway.
I guess I will plan on trading it off for a regular FWD sedan or hatchback this fall.
You could temporally disable the rear drive by disconnecting the 4WD ECU which is mounted behind the glove box. In fact there is just one wire coming out of it that goes to the rear electro-coupler.
If I had the problem I'd put a switch in it rather than give up a 4WD vehicle for a FWD or a 4X4 one.
As I said in the previous thread, this problem only happened to me once in 8 years of ownership. Although I can drive through deep snow as well as I could in my Jeep Cherokee, these unusual road conditions brought on the same symptoms that you experienced.
I believe they were caused by the side effects of traction control. I couldn't prove it at the time because I did not have the procedure for disabling traction control with me.
If this occurs on a regular basis then I suggest disabling traction control according to this procedure next time you experience the problem.
^^^ What Rickl said. This is a classic case of engine bogging down when stuck, so you must disable the TRAC/VSC system:
Read the link he posted, here is the 'tap dance procedure' from the link. Seems crazy. Starting in 2009, there is a simple button you push and hold for 5 seconds, but you get to do this:
from JuneBug post:
1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
2. Start the engine.
3. Engage the parking brake.
4. Fully depress the brake pedal and then release.
5. Fully depress the brake pedal and then release.
6. Disengage the parking brake.
7. Fully depress and hold down the brake pedal.
8. Engage the parking brake, then disengage it (while holding down the brake pedal).
9. Engage the parking brake, then disengage it (while holding down the brake pedal).
10. Release the brake pedal.
11. Engage the parking brake.
12. Fully depress the brake pedal and then release.
13. Fully depress the brake pedal and then release.
We've had some record snow this year, been testing the system, have switched off TRAC/VSC several times when engine bogs. Luckily, I have the magic 'button.'
when the engine bogs down because of VSC the 4WD light does not turn on.
I did have the 4wd light come on once in 10 years of owning Rav4, VSC was deactivated and I was having fun in the snow, after 2 minutes of pushing it, power was limited and party time was over...
Doing the two step jig on the brakes to turn of traction control helped a lot. I was able to get through the rest of the worst weather without issue as long as I did this before I headed down the bad roads.
Now the car is in the shop getting a water pump though LOL.
As mentioned earlier, the 4WD light was coming on because the system was overheating. Most likely caused by the clutch in the rear differential constantly engaging and disengaging. Simply pressing the 4WD lock button on the dashboard will stop that problem, assuming your speed does not exceed 40 KMH , above which the lock will automatically disengage.
Related Threads
Toyota RAV4 Forums
993.1K posts
147.9K members
Since 2004
