Got the dreaded CEL, VSC and 4WD/ Traction lights on, hook up scanner, three codes show up, P0017, P1578 and C1201, got battery check and load tested, found battery was bad and replaced, after installing new battery, all lights went out, after driving about 50 clicks, CEL, VSC and 4WD/ Traction came back on, hook up scanner, two codes came back, P0017 and C1201, any suggestion on P0017 fix , engine got 120Kms.:confused:
Oil control valve is the only other thing I can think of. The other codes are likely just thrown up due to the P0017 (engine system malfunction and brake system failure due to VSC OFF) I'd take it to a mechanic you trust for an official diagnosis though.
Sent from my SM-G928V using Tapatalk
