So I have been looking to lift my 2008 rav for quite some time and through quite a bit of research, I had found out that a certain company offers a lift kit for the 4.3 that has a lift of the bottom spring perch to allow for larger tires.
The struts in question are bilstein b8 5100
Front left model # 22-310392
Front right model # 22-310408
Throughout my research I learned that bilstein has since seemed to discontinue this product line and replaced it with the new b8 terrasport line.
Front left # 22-328403
Front right # 22-328410
These struts above don’t state that they fit the 4.3s and that they do fit 4.4s
Keep In mind that my application is an awd model, however I don’t know if it makes any difference. I found that a lot of parts that make up the suspension of these two platforms are cross compatible.
The first two part numbers above are the ones I opted to purchase because I was able to track a set down and get them shipped to my house in less than a week, the terrasports appear to be shipping early February 2023 and I didn’t want to wait.
Everything about the b8 5100s are the same as factory as far as mounting to the vehicle and the install went very smoothly and my vehicle gained exactly 1” of front ground clearance and it appears that there is now room for at least a 32” tire (on the strut) however I’m not sure I recommend that large of a tire for 4.3s
Note these parts listed above are a strut ONLY, they do not come with the upper spring land, strut top hat, rubber dust boot, spring, or rubber bump stop. I chose to use all of those parts that were on my car and replace them later and just replace the strut.
