1 - 10 of 10 Posts
Change:
-Coolant
-Transmission oil
-Transfer case oil if AWD
- Rear differential oil if AWD
- Spark plugs
- Air Filter (if dirty)
- Cabin Air Filter (if dirty)
- Brake Fluid
Check , Service or Replace
- Brakes
- Caliper Slide pins (clean and apply with silicone grease)
- front struts
- rear shocks
All is done except transmissions fluid ,brake fluid and spark plugs .
Spark plugs would be a good idea , even though they are good for 120,000 miles .
I hope you already changed your transmission fluid and gear oil at least once, if not , you're do for sure.
Brake fluid? Never did it before without having to after a repair for the last 30 years. Change it if you like.....
Servicing your calipers is a good idea to prevent premature pad wear and the calipers from sticking.
Change your air filters if necessary and add some Seafoam or Marvel Mystery Oil to your fuel and keep on trucking.
You must drive a lot! Already have that mileage with a 2011.....my 08 just turned 160,000 km's (99419 miles)
Discussion Starter #8
Yea all highway. Drive down south to . All is done except brake fluid,belt,spark plugs
Take care of the remaining items and drive it another 100k.
Enjoy your Toyota now that it's finally broken in.
1 - 10 of 10 Posts
