Hi there..new to this forum. Hope message is going to the right place. I own a 1996 Rav 4. Have had it for 6 happy years. Recently its started dying on me in traffic? If i wait 45 min it starts again and can get home? No alarm system. Have replaced coil and ignitor and fuel pump. Have tested spark when it dies and at that time no spark? So its not fuel! There is also no crank shaft sensor down below by the crank pulley? Should i look inside distributor? Any help will be appreciated?
What's an "ignitor"? Do you have the gas 3S-FE?
Done all the other normal maintenance, e.g., spark plugs, spark plug wires, air filter, fuel filter, etc.?
Replace the ground strap, and add an extra, if not done yet.
But could be many things. Try opening the gas cap after it dies, then try restarting.
2.0 petrol engine. Not fuel as ive mentioned. When it dies i check for spark. No spark at the time of test. If i wait 45 minutes its got spark again. Have not got fault codes.
