T
Toadie77
·Guest
Hello~
I'm a new Rav4 owner 1996 4-door with stock motor and Auto trans. I'm living in Japan right now, so I was hoping to get some help from your forum.
I was getting ready to change the oil, and I noticed that I had some type of fluid leaking under the car. It is to the drivers side of the oil pan (looks like the trans / differential area). The leak is coming from the rear of the square pan next to the oil pan and looks exactly like used oil. I do not think it is motor oil because when I use the dip stick the motor oil looks “cleanerâ€. Could it be transmission fluid?? FYI, My oil level has been fine so far, but I was changing it to synthetic.
I have about 50k miles on it but otherwise it seems to run fine for me.
Would it be worth it to order a shop manual? Any ideas on what could be leaking / how to check the Trans oil level etc would help. (the owners manual is entirely in Japanese).
I did try a quick search, but sorry if this topic has been covered and I missed it.
Thanks!
Greg
Thanks!
Greg
