Yes you can. In this case whatever works works.Can I fashion a replacement or duct tape it back and hope clearance is right? Thanks.
I understand that and agree. Hence I am promptly working to rectify it. I will check your link. Thanks.That means you have brake lights "on" while driving - that's a highly dangerous thing because people behind you cannot see when you are really braking. That's why is illegal to drive the car like that.
I thought that there is an adjuster nut on that switch?
Toyota RAV4 Service Manual: Brake pedal - Brake (trav4.net)
ElleThe cushion labeled 47131 below is for the brake light switch on a first generation Rav4. It is likely what you need. It is Toyota OEM p/n 90541-06036.
For the archives, the switch at the brake pedal is p/n 84340-32090.
I too have seen these cushions for switches on the clutch pedal and brake pedal wear down and require replacement.
how soft is that plastic? have had a penny on my crv for almost 9 years now.The reason there is a soft piece of plastic there is to be a cushion to the brake switch. Putting a piece of metal instead will eventually damage that switch.
Wow! Here we are over a year later on this thread. I guess I never reported back its full resolution.use laundry detergent bottle to make a new plastic button
and super glue stack them for the shim spacing.
yup been there on this in the service shop.
all brands of cars and trucks.
brake light switches just go bad over time on the plastic.
replace the switch and check the button shims and adjust to correct on off spacing.
