Stick a penny in there and see what part of the car catches fire?
Sorry.
Sorry.
Do you think it could be the headlight dimmer switch? The fuse only blows when the running lights are on.A short. I'd look first at wherever the wires go through moving parts, like the door(s).
Yes its 23. Ive tried driving with just the running lights on and it still blows. Ive noticed that when I brake the dash light flicker before the fuse pops. I though maybe it was a bad bulb in the cluster but I replaced all of them. When I first bought it a year ago I had the same problem but I replaced a bulb in the cluster and I was good to go. This time nothing is working-- Hondaguy93, are you handy with a multimeter and reading electrical schematics?
-- Please confirm: Is it fuse #23, as shown in the drawing at www.autogenius.info/toyota-rav4-xa10-1998-1999-fuse-box-diagram/, that keeps blowing?
-- If possible, post a photo of the fuse box that identifies the fuse (fuses?) that keeps (keep) blowing.
-- I would start by disconnecting the plugs in the engine bay for the headlights. Run the Rav4. Does the fuse (fuses) keep blowing?
-- I am looking at the 1998-2000 wiring schematic. If you search for 1999Rav4wiringdiagrams.pdf, you can download it. In particular, I am looking at pages 24, 30, 40 and 42.
-- If you answer the questions above, I can probably offer a systematic approach that may help you find the fault/ground/short as quickly as possible.
I have a meter and im handy with electrical scemes, I just haven't been able to find the right wiring diagram for the brake system. Also this started a day after I put a new battery and alternator in.Yes its 23. Ive tried driving with just the running lights on and it still blows. Ive noticed that when I brake the dash light flicker before the fuse pops. I though maybe it was a bad bulb in the cluster but I replaced all of them. When I first bought it a year ago I had the same problem but I replaced a bulb in the cluster and I was good to go. This time nothing is working
Inspect all around the brake pedal, up under the dash, to look for wires being rubbed/bent....when I brake the dash light flicker before the fuse pops.
It only blows from braking on occasion. That's when I noticed the flickering in the gauge cluster. It randomly blows but only when the running lights are on. I could drive all day without them on and the fuse is fine-- Hondaguy93, are you saying that the fuse blows when you press the brake pedal?
-- Attached are a couple of sections from the 1998-2000 Rav4 service manual that I am using. The Tail Fuse (fuse #23) appears on pages 24, 40 and 42. Page 30 seems helpful as well for a DRL equipped Rav4.1.2.
I just checked that and nothing out of the ordinary down thereInspect all around the brake pedal, up under the dash, to look for wires being rubbed/bent.
I tried to take that turn and gauge fuse out and it seemed like it caused it to blow even faster. I don't know if I mentioned this yet but this only happens when I'm driving. I left my car running for 2 and a half hours the other day and the fuse did not blow. I mashed the brake pedal while it was sitting running And I accelerated the engine. Perfectly fine until I tried to drive-- Hondaguy93, are you saying that the fuse blows when you press the brake pedal?
-- Try this: Remove the 10 amp "Turn & Gauge" fuse. The "Turn & Gauge" fuse is in the same box as the Tail Fuse. Start the engine. Does the Tail fuse still blow?
-- Please confirm: Were the running lights on when the Rav sat and idled for those 2.5 hours?I don't know if I mentioned this yet but this only happens when I'm driving. I left my car running for 2 and a half hours the other day and the fuse did not blow.
