1 - 20 of 66 Posts
'99 RAV4.1, '06 Yamaha Rhino 660 UTV, '96 Newmar Mountain Aire 40' Diesel Pusher Class A Motor Home
Okay lets be real, the stock 4.1 RAV4 is not a very masculine looking vehicle so I installed a few upgrades and still have a lot to do.>:D
My RAV4 is my office and I needed a vehicle that could get through mud, sand, brush and comfortably drive coast to coast and then do it all again. My job is 4 wheeling and blowing stuff up!!!
See my garage: http://www.rav4world.com/forums/garage.php?do=viewvehicle&vehicle_id=8241
________________________________________
Installed:
- 1 ea - 1996-2000 Toyota RAV4 Black Grille Bumper Guards Brush Bull Push Crash Bar (ChromekingUSA an eBay store)
- 1 ea - K&N 57-0315 57i High Performance International Intake Kit (amazon.com)
- 1 ea - Curt Manufacturing 13524 Class III Receiver (amazon.com)
- 1 ea - Old man Emu Lift Kit (doesn't include front struts)(Toyota Rav4 lift kits, suspension, fender flares, part & accessories at the lowest prices)
- 1 ea - Daystar KT09105BK Comfort Ride 1" Front Strut Spacer Kit (note not for RAV4 but it works with a little effort) (amazon.com)
- 2 ea - Monroe 903995 Strut-Mate Strut Mounting Kit (amazon.com) You should add these to any strut replacement.
- 1 ea - Gabriel G56631 Ultra Gas Strut, Front Left (amazon.com)
- 1 ea - Gabriel G56632 Ultra Gas Strut, Front Right (amazon.com)
- 5 ea - Rims 16x7.5 Anthracite w/Mach Lip American Racing Razor (tirerack.com)
- 5 ea - *Tires - 235/75R16 Firestone Destination A/T (tirerack.com)(these tires are 30" tall and caused some rubbing issues that I had to repair with the judicious use of an implement of destruction (4lb hammer) to the rear of the front fender wells and removing those weird things that bulge at the rear of the wheel well and by using the following wheel spacers.)
- 2 sets - 25mm (1") 5x114.3 Hubcentric Wheel Spacers (amazon.com)
- 2 sets - Gorilla Automotive 21133HT Small Diameter Acorn Chrome 5 Lug Kit (12mm x 1.50 Thread Size) Pack Of 20 (needed some for the spare)(local purchase)
- 1 ea - BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible (amazon.com) Can be used in other vehicles.
- 1 ea - 24F sized battery and tray; fits nicely, probably could have gone up a size.
*A word of advice; the largest tires that you can get under it with this lift kit are 29 inches and maybe they won't rub in the front, 30" tires rub harshly on almost any turn and require some vehicle modification (wish someone had mentioned that). :wall The tire/rim fits fine on the rear tire rack, no spacer or mod needed.
Things to come:
- Mossy Oak "Obsession" pattern vinyl vehicle wrap. I have this just need a little time to apply. Will paint the side kick panels, bumper covers, and fender flares.
- 1 set - Hood Vents - Size Large Powder-Coated Semi-Gloss Black Hi-Flow™ 2 each 11" x 17" Angle Cut Vents (http://www.hoodlouvers.com/product-c...ershood-vents/),
- A 3SGTE engine (if that noise from the engine is something bad or maybe just do it because it sounds like something awesome to do).
- Upgraded front seats or perhaps the right super comfortable seat covers for long distance comfort - any suggestions?
- Upgrade the radio and speakers.
- Custom skid plates to protect gas tank, engine, and tranny. Too bad no one makes them, but I'm sure I can fabricate them.
Gator
“People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.”
Looks pretty good to me! Nobody will mistake that for Mom's grocery getter! But where are the roof rails???
Discussion Starter · #3 · (Edited)
Thanks, left it off my list, somebody liked them more than me and they disappeared along the way. Yes, a roof rack is also in the works.
Thanks, with the oversized tires she's slow off the line so I'm seriously considering the upgrade. A rattle from the engine has me a little spooked too.
I think my engine noise is from the timing belt, tensioner pulley, and/or water pump. Ordered a kit that includes all those nasty little things, and a thermostat, all belts, radiator and heater hoses. Hopefully that fixes the issue. Also doing a complete brake job new master cylinder (old one leaking), rotors, calipers, pads, flex hoses, drums, shoes, and drum kit. I was looking at going with rear disc brakes, but for now finances dictate staying with drums. I at least put drilled and slotted rotors on her.
What is your gas mileage with the new tires?
Reactions: eodgator
Gas mileage
Leon, I really haven't checked; when I get it back on the road I'll check and post it. I would expect it to be lower around town but better on the highway.
It's down awaiting parts for a brake rebuild, 5th gear fix, and timing belt/water pump replacement. Should be complete early next week.
Discussion Starter · #9 · (Edited)
Well I decided to repair the engine rattle, after checking it out it sounds like a timing belt issue, so I ordered a kit which included the water pump, timing belt, pulleys and gaskets. I also ordered all new radiator and heater hoses, thermostat, new belts, and valve cover gasket. And as long as I was here, decided I may as well take care of putting in a new oil pump just in case that was a problem. To do all of this you must remove the valve cover (to hold the cam shafts stationary while you remove the cam pulley).
Not going through a step by step procedure here for everything but to break the crankshaft bolt loose, perform the following steps...
1) Make sure your timing belt is still installed, if not, reinstall, making sure you put it on properly.
2) Recommend using a pneumatic 1/2" drive 14mm socket and a 1/2" breaker bar, wedge the breaker bar into the control arm, put the socket on the crankshaft bolt turn the harmonic balancer until you can attach the breaker bar into the socket.
3) Ensure the breaker bar is securely wedged.
4) If you disconnected the battery, reconnect.
5) Disable the ignition (you don't want to start the engine) in other words disconnect the spark plugs or disconnect the crankshaft position sensor.
6) Turn the engine over briefly twice.
7) Check to see if it broke the crank bolt loose, if not try again (I've never had to try again)
8) Now before you remove the camshaft pulley or the harmonic balancer, make sure the engine is at top dead center (TDC).
This will save you lots of frustration and your girlfriend won't learn your full curse word vocabulary. LOL
Be carefull with the crankshaft pulley if you bend or break those pins the crankshaft sensor won't work properly. Already did that once.
Discussion Starter · #12 ·
Now, if it would just stop raining so could get it finished.
Discussion Starter · #13 ·
No, it's a 4 banger. I guess I'm old, what does "this is so dope" mean? Nevermind, I looked it up, thanks.
Haha...sorry...Just means i think its awesome..... I have a 4 cylinder too......Do you feel a big difference after putting in that air intake? My car runs sort of slow and noisy...I'm thinking this may help give it some OOMF
Discussion Starter · #16 ·
The intake made the engine sound better, RPMs increased a bit. Not going to get a lot of performance from the 2 liter engine that comes with the US 4.1 RAV4s. Plan on later installing the 3SGTE engine, going from 127 hp to 300hp ought to be a kick in the pants.
Discussion Starter · #19 ·
Found the engines on ebay complete for about $1000 but you have to upgrade the clutch and add a functional hood scoop for the turbo intercooler.
Discussion Starter · #20 · (Edited)
Repairs to the engine complete, new oil pump, water pump, timing belt, pulleys, all belts and coolant hoses. No more bad noises from the engine, no leaks, no left over parts.
Now time to do a complete brake job so, all flex hoses, master cylinder, rotors, calipers, pads, drums, shoes, wheel cylinders, misc hardware.
Rain slowed me down, at least I got the front passenger side brakes complete and the calipers for the front driver side assembled. Should go quickly in the morning.
1 - 20 of 66 Posts
