Had the 32k km service done today - rotate tires, change oil, brake service & replace cabin air filter. Good for another year (except for an oil change). They also replaced the roof moulding that had come loose. Looks like it's held on with just 2-way tape.
Canadian 32000Km(20k miles) isn't the same as US service, Canadian requires brake service(removing calipers, rotors, drums for inspection and measurement according to the Canadian maintenance schedule. https://www.toyota.ca/toyota/en/my-toyota/maintenance-menu
20k mile US maintenance only requires inspection of brake components.
US 20k Miles/24 months
Check installation of driver’s floor mat
Inspect and adjust all fluid levels
Inspect wiper blades
Replace engine oil and oil filter 1
Rotate tires
Visually inspect brake linings/drums and
brake pads/discs
Additional Maintenance Items for
Special Operating Conditions 2
Driving on dirt roads or dusty roads:
Inspect ball joints and dust covers
Inspect drive shaft boots
Inspect engine air filter
Inspect steering linkage and boots
Re-torque drive shaft bolt
Tighten nuts and bolts on chassis and
body
Driving while towing, using a car-top
carrier, or heavy vehicle loading5:
body
Brake service, was it just a check to see if pads are OK, or did they do something?
Here's what the work order says:
Replace oil & filter
Check driver's floor mat
Inspect cabin & engine air filters
Confirm lights, horn & wipers function properly
Inspect & adjust all fluid levels
Perform 12v battery service
Inspect drive belts, adjust if req'd
Inspect steering gear, linkage and shock absorbers for looseness, damage or leakage
Inspect ball joints & dust covers for looseness & damage
Inspect fuel system for leaks or damage
Inspect exhaust system for leaks or damage
Inspect and measure brake pad thickness
Inspect brake caliper and rotor condition
Rotate tires, Check & adjust pressures
Road test
The 4 wheel brake service was extra & included:
Remove front brake pads - sand, clean & lubricate. Lube sliders.
Clean/lube/adjust rear shoes or pads.
So if you do your own repairs, you still have to go the repair place to get certified? Then you can do the work yourself if it failed? Then do you have to go back to get re-certified, or will the brake pad and rotors receipts be fine? What does an inspection cost is US dollars?
