I can see from your profile that you a 4WD. Ideally, I would replace all 4 if only 10K miles are left.
Have you checked a used tire place; they might have exactly what you need regarding size, maybe even brand. You would need to measure the circumference of one of your tires using a string and compare.
You could also buy one tire and have it shaved to match if have a tight budget.
On the other hand, I would like to know the circumference of the new tires compared to the 2 tires that you were planning to keep. I believe it is ok to have a 5% difference in circumference for the RAV4 4WD system to operate. Otherwise, it is automatically disabled.
