Hello I just brought a 2001 RAV4 and it sounds like the timing chain has snapped? Is this Likley or could it be something else? Any help would greatly appreciated
It is not likely the timing chain. It is made of metal unlike the rubber timing belts. Check the battery with a volt meter if it has 12 volts. Does the radio or head lights come on. Maybe the battery is dead.
So i pulled off the Rocker cover and it's stapped the front cam gear and the motor is sludged up!!! Would you suggest to try and fix it or should i replace it? Has anyone got suggestions to to properly clean out the sludge? Also what should i replace?
I can only imagine what the bottom of the oil pan looks like. You will spend a lot of time and money correcting this. Any recourse with the seller?
