Finally did it today and wanted to share my experience with my board pips. Unfortunately I couldn't find any detailed pics or videos online on how to remove headlights from 2002 Rav4. The whole job took 3 hours and half of that was thinking how not to screw up and break anything. My Rav4 is old and rusty but this upgrade was meant to improve night visibility for my wife so forgive me the rusty spots on my car. The biggest problem was with removing the lower panel just below the radiator and above the bumper. The 4 plastic bolts, 2 on each side drove me CRAZY!!! I found no easy way to remove this panel without damaging these bolts, lol. I think in the near future I will have to replace the whole panel along with new bolts, but I am done for now. Both headlights I got from Amazon for $98, and LED kit also from Amazon. The LED Kit i chose was with the Copper Heat Sink rather than fan due to a very little room behind the headlamp. These LED's were little different as they were designed with a little nud on the bottom side of the bulb covering the low beam from bottom side of the reflectors minimizing the glare for the upcoming traffic (will see if its true tonight).
Headlights are clean and bright. Although they didn't fit perfectly, bigger gaps around headlight comparing to the stock. As mentioned in some posts I didn't have to remove the whole bumper, only the screw on top of the bumper cover next to the fender and then just pulled the top of the bumper cover down without removing bottom screws. I used 10mm wrench for all the screws and to adjust the headlight 8mm one. Can't wait to see the light pattern on the street tonight. Will update with new pictures.
