1 - 1 of 1 Posts
Hi Guys.
This Rav has been flawless! It will idle but if you put in gear it will rev to 2000 rpm then it cuts off, stumbles and then settles back into idle. Codes are p1135 and p1155. Is there such a thing as limp mode?
I have the ECM rebuilt three years ago to fix the transmission. Do I need a new computer or are the two top AF sensors on the Cat at fault. will they cause this issue?
When it stumbles the CEL and the auto trans warning light flash.
This rav has worked so well now I'm stumped.
original owner, 300000 kms and well looked after.
Planning to get to at least 400000.
1 - 1 of 1 Posts
