Hello all. I've been SCOURING these forums. None of the previous threads have helped.
Here is my situation...
I have the 2003 Rav4 base model. Originally came without fog lights. I installed the fog lights using the already existing wiring hardnesses. The issue now is that they dont turn on.
On my interior I do not have the new stalk with fog. I do have a toggle button which when pressed does turn on the fog light instrument cluster light. But the fogs still dont turn on.
I checked the fog fuse, looks like its good to go. The fog relay I couldnt find, but all relay spots seem to be occupied. I just placed an order on eBay for the fog stalk, but shouldnt this work if its lighting up the fog light symbol on the instrument cluster?
Thanks!
I did the same conversion as you, but I used the OEM foglight stalk w/ OEM lights. Works and looks factory, because it's factory parts. I would advise against using a toggle switch, just use the OEM stalk, it's $30
Probably would've been better if you checked to make sure you were receiving 12v at the bulb connector or checking your ground connection. Who knows....are you even sure there was a light bulb connected to the fogs?
Must be a missing fog light-relay, you can find the empty spot lying on your back under/behind the steering wheel (use a flashlight). It's next to the horn-relay.
