21 - 40 of 79 Posts
At least with the back lifted, the roof is now straight leveled haha!
Discussion Starter · #22 ·
Motor vehicle Rectangle Gas Asphalt Font
Half of the parts have now arrived.
If you don't know. Australia has one of the world's worst logistics companies, along with businesses who sell from eBay. Another week away is the rest of the parts... Hopefully (Same seller, different warehouses in different states... Sigh..)
Did you bought the protection boots that goes over the front shocks rods? Your shocks will last longer with boots.
Reactions: Coff33
Discussion Starter · #26 ·
Hey All,
As we all do, i couldnt wait for more parts to arrive without doing "something"
So decided to install the rear Ford Escape / Mazda Tribute 2001 shocks .
A size comparison :
Musical instrument Wood Art Cylinder Composite material
Road surface Wood Asphalt Musical instrument Font
As you can see, the lower bushes are different. RAV4 Toyota has only the rubber bush to slip over the lower mount.
The Ford Escape / Mazda tribute shocks have a metal tube.
Even though my purchase of these was based off a Russian forum, which was translated into English, the bush part worried me... none the less I continued
Tire Wheel Automotive tire Tread Synthetic rubber
I greased up the lower shock mount pin. Assuming they were going to fit, I'd rather not have RUST eat its self between the shock bush mount an the lower mount.
Automotive tire Motor vehicle Vehicle Automotive exhaust Rim
To my surprise the shock pushed straight on, Almost a "PRESS-FIT" onto the mount. There is literally ZERO movement of the tube on the shock mount!! Amazing!
Tire Wheel Crankset Automotive tire Bicycle tire
The factory Toyota mount bolt fit fine, with plenty of turns (5 rotations) and secured the shock fine on the mount.
Automotive tire Gas Automotive wheel system Circle Metal
Up the top, The factory Toyota 14mm Nuts also fit on just fine, using the new rubber isolators which came with the Ford Escape / Mazda Tribute shocks .
I went for a test drive an they feel a lot more supportive and rebound is a LOT more improved.
Highly recommended.
Very interesting! You can gain for sure one more inch to the lenght because you have two nuts one over the other.... and there is still some more threads left. So I will also buy these shocks on my ''new'' RAV4, and put a metal sleeve under the bushings area to get the maximum lenght out of these. Thank you for sharing!
Reactions: Coff33
Discussion Starter · #28 ·
Today I installed a 4.3 ACA3X Steering wheel into the 4.2
I havent figured out if I can make the steering wheel buttons work without getting a 4.3 clock spring. Even then, I would need electrical diagrams of 4.2 and 4.3 to figure it out and in Australia we do not have a freedom of information act. Therefore no information would be available for that. Maybe something to look at in the future.
Indicators turning off when turning corners work fine though. Which is all that I really need.
Anyway, nice leather wheel, I sanded it back slightly and gave it a re-coat using Fabric and Vinyl paint.
Much nicer than my "rubber/plastic" wheel which had chunks missing out of it.
Land vehicle Vehicle Speedometer Car Steering part
Discussion Starter · #29 ·
Removed the Suzuki Grand Vitara 17x6.5 wheels and Toyo Open Country 225/70/17, as they were making a lot of noise, and didnt really feel "right"
Installed some Toyota Kluger 2007 wheels. They are 16x6.5J +35 Offset. So that gains me 10mm more track! which is nice!
(note: Kluger in Australia is Highlander in US/Canada etc)
I plan on fitting some 245/70R16 A/T tyres. Just havent completely decided on a brand yet.
I also moved my sand recovery boards from the side of my roof rack, to on-board the roof rack. I felt as if they were really disrupting balance on the highways at 100kph.
Still waiting on Australia Post for my parts. Hopefully this week I receive them and can get a move on installing them.
Sky Wheel Car Tire Vehicle
Automotive parking light Car Land vehicle Wheel Vehicle
Plant Car Vehicle Hood Sky
Discussion Starter · #30 ·
Well, again some parts arrived from the east coast of Australia. Only took 2 weeks for these to leave a warehouse and get to my house... LOL
Anyway this time I received the KYB top mounts for the front struts.
Camera accessory Camera lens Cameras & optics Gadget Digital camera
I removed the short standard 3 knurled bolts from the top and used a wire wheel to grind off some of the paint around the base.
I grabbed some M10x65mm bolts
Automotive tire Automotive lighting Motor vehicle Wheel Bicycle part
Using my MIG, I welded the bolts to the base of the mount.
Automotive tire Gear Rim Bicycle part Motor vehicle
Sadly,
After hours of work , I could not get the FJ cruiser or LandCruiser Prado springs to sit right and work on the strut. So I'm slightly disappointed in that. However good news is the struts are now fitted and feels fantastic to drive on
Black Road surface Tints and shades Gas Symmetry
Automotive tire Camera lens Camera accessory Tread Cameras & optics
After further inspection of the 2004 Toyota OEM shocks. One was completely blown and sank right down when was changing over the springs.
I guess eventually I'll just bite the bullet and purchase some King Springs from EBAY to get an extra inch of lift in the front.
Discussion Starter · #31 ·
Oh and I also painted my OEM nudge bar Satin Black, looks much nicer now.
Im considering painting the F and R bumpers and side door moulding plastics satin black too....I wonder if that would look good or not... hrmmmm
Wheel Tire Automotive parking light Car Land vehicle
Automotive parking light Wheel Car Tire Automotive side marker light
Discussion Starter · #35 ·
Wheel alignment complete.
My toe was WAY off after strut replacement. Quite strange considering the tierods/rack ends are not modified during the strut swap out...
Car feels good again. Just in time to go camping this weekend in the Western Australia Perth Hills.
Weather is going to be rain, so mud and wetness ... Fingers crossed it's loads of fun!
Rectangle Purple Wood Font Line
Wheel alignment complete. My toe was WAY off after strut replacement. Quite strange considering the tierods/rack ends are not modified during the strut swap out..
When you lift the RAV4, it acts like if you had shortened the tie-rods... so the front wheels get a bit tow out.
Two bolts aren't ideal, but you don't want positive camber, it gives understeer, or push. The bolts are quite big, so should give enough clamping force. You want 0 - 1 degree negative. Plus 0.5 degree difference between left and right is too much.
Another option is to drill one extra hole in the wing, so that you can turn the top mount. Though the three bolts look like a perfect triangle, they're not. This gives a touch more camber and caster. I'll take a photo of mine tomorrow to show what I mean.
21 - 40 of 79 Posts
