1 - 20 of 22 Posts
Our Rav4 burns oil. I have to add a quart or two every week. There is no smell and no smoke from the exhaust.
Can it be the PCV valve?
Sent from my SM-G935P using Tapatalk
Your 2006 is too late to the game--the 2006-2008 4-cylinder oil burners were a problem Toyota has offered to test and fix, but now the car must be within 10 years of first date in service. Here's a couple of links to read through:
http://www.rav4world.com/forums/99-...per-ze7-extended-campaign-22.html#post2269186
http://www.rav4world.com/forums/99-4-3-mechanical/191889-another-oil-consumption-post-2.html
The only cars remaining for coverage must be under 150,000 miles and less than 10 years old. Up until Oct 31, 2016, everything was covered with unlimited miles. The problem is with the piston and ring design and involves a major rebuild to fix.
I'm aware of the oil consumption test. We took it in when it was happening but the e car passed.
I'm aware of the oil consumption test. We took it in when it was happening but the car passed.
Well, either the test was poorly administered by the dealer or the problem has now surfaced. Approximately how long ago and how many miles did the car have when you took the test? What was the rate of oil burn when you took the test compared to now? You won't be covered, but it might be useful for others to know.
Most people in your situation just buy cheapest oil possible, check oil level at every fuel stop, and keep feeding it if car seems to run okay. The rebuild would be expensive on your dime.
I'm not sure the car now has over 160 miles. At the time of the test maybe around 130 maybe more.
A mechanic told me to buy full synthetic and to get a filter that's better. I forgot what filter he said. He told me is the rings and full synthetic should burn less fast. Is this correct?
Many folks have tried to cure the problem with various weights of oil, brands, synthetics, additives, cleaners, etc. You can try whatever but it likely won't fix what is really a mechanical defect with the rings. If you find it still burning it up, just buy the cheapest possible oil by the case, IMO.
I'm curious what the dealer told you about the test results, and if you were already observing a high burn rate at the time of the test at 130k?
Discussion Starter · #9 ·
They just told me it was good and passed. I was naive and didn't ask much. He said a second test was not necessary and never took it back. My mistake.
The oil I can try has to say full synthetic right? What filter?
Some Dealers were negligent on doing the test properly, IMO. If this particular Dealer cares about your business, you could bring it to their attention that the car is now burning oil badly and likely was during the test, as it wasn't so long ago. Extract some "good will" from him to give you a $3,000 discount (value of their poor test, missed diagnosis and no rebuild)-- on a trade in to a 2009 or newer RAV, which has the better engine. Okay, maybe I'm dreaming here--the Dealer is likely a scoundrel and best approach is to never cross paths again.
As far as synthetic oil and filter: Maybe others will chime in, but I have zero confidence in this. You can always call and ask the original mechanic who recommended this approach. It's a classic blow-off technique to get you out the door, and waste even more of your money. Be sure to call him back when it doesn't work out.
Discussion Starter · #11 ·
Someone said coolant might be leaking in the oil. How can I know?
No, NO, NO!!!!! Synthetic oil will NOT stop or slow the consumption. As pointed out above this is a mechanical defect. Synthetic will double or triple the cost of the oil you will still pour in the engine every 1000 miles or so. Filter brand at this point doesn't matter.
The mechanic that told you that has no clue whatsoever.
Discussion Starter · #13 ·
I checked the pcv valve and it rattles but when I blew out air came out like it should. When I blew in there wasn't much resistance as some air would go through. I went ahead and changed it. We'll see but I hear you most likely it's a mechanical defect from Toyota.
As far as full synthetic I'm listening but my neighbor placed full on his truck and the burning stopped.
I can't see that an engine burning oil would be very picky about whether it was synthetic or not. But it would be easy for you to find out for yourself.
I don't believe that for one minute.... and it was a RAV4 with the 2.4l oil burner engine with 160,000+ miles on it?
Do as you wish but
Discussion Starter · #17 ·
Do as you wish but
I see your point. How about the pcv valve. Can that cause issues.
I currently own a 2012 3.5l Limited but the car I traded in for it was a 2009 Corolla which shared this 2.4l engine (2AZ-FE). I owned it from March 2016 until September 2016. Here are a couple of observations I had about this engine from my experience if this helps:
-I had close to 78,000 when it was traded in for the Rav4. During my short time owning it I went through the same experiences you had. A LOT of run around, a lot of other forums and similar experiences.
-I typically change the oil in my vehicles twice a year, about ~5,000-7,500 miles between or no more than 6 months elapsed between changes and always with synthetic (which right or wrong is always what I have done on my vehicles). Upon changing it out as well as checking the levels during gas fill ups, the oil was always darker and smelled burnt. Several times out of curiosity I opened the oil cap at the same time and smoke would rise out from the block/valve cover. It wasn't a faint smoke nor a thick smoke necessarily, but a clearly obvious burning oil smoke wafting out from under the oil cap.
-In the 5 months I owned this vehicle, I changed the oil twice due to these reasons. Clearly the engine was was burning as well as consuming oil. To be fair I drove it mostly daily in city with two longer extended travel trips. About 6,000 miles total.
I read the literature on Toyota's lack of response over several years, and then finally their reluctant procedure to check it at dealerships. I don't remember at this point what specific amount of oil had to be "lost" between changes in order for them to rebuild the engine but I do remember it is a significant amount , i.e.:
-You typically would have to be burning/losing so much oil that the engine would be at the full mark and have to be below the low mark on the oil dipstick after 30 consecutive days for them to consider further investigation.
-The dearlerships I talked to said Toyota only allowed 2 attempts to show this was the case with your engine. If you got close, like I did after doing the test, that didn't count and you were allowed to try one more time to "prove" your engine was "not at operating standard". If however, like my vehicle, it burned all the oil down to just above the low mark after 30 days that did not count as Toyota considered this "normal wear and driving". Clearly this is NOT normal for any given standard consumer vehicle engine.
-They did this investigation by you starting a complaint. The dealership would take the vehicle and do the oil change for you. They would mark the drain plug, filter, and oil cap with a light colored sealant to make sure you weren't tampering with adding/removing/changing the contents. You were given a set amount of time to drive the vehicle, I believe it was 30 days. At which point, you returned to the same dealership and they would change the oil for you and document the differences.
-If they determined your car was consuming a lot of oil, they would then grant you (I believe) a loaner car and the dealership would go about replacing the piston rings and I believe pistons. Who knows how long they would keep the vehicle for in that case.
From what my nearest dealership told me (and I've had a lot of good experiences with mine) is that carbon builds up on the first piston rings and over time creates wear and or breakdown to the point where oil is then slipping past and burning. Toyota created this final solution to test vehicles and really try to minimize their damage by making it very difficult to fail the test. In this case only the absolute worst offenders where the engine barely goes a few weeks before needing oil added would even be considered to be replaced. And like others noted there was a timeframe as well in how many miles and/or years had passed before you wouldn't be allowed to even ask for the testing to be done. Essentially, Toyota knew there was a big problem with these 2AZ-FE engines from all the complaints across many models and they had used them in several Scion models all the way through some Corollas, Camrys, and the Rav4 (I believe some earlier Highlander models as well). Because of this they replaced this engine with an updated 2.5l engine which is now used in many vehicles including the new Rav4s which don't have this issue.
Like others have noted and it sounds like you know it is a big problem. I personally didn't enjoy the used Corolla I bought anyway so after all these engine issues I gave up and took a big loss to get out of it and into something I wanted rather than drive something that wasn't useful to me and came with a lot of constant maintenance issues. Having said that I think the others are right. If you stay on top of adding oil in every couple of weeks and you're good about maintaining much more regular oil changes then these engines should last you a good long while it's just that they burn a lot of oil. I personally love my V6 Rav4 and it may so far be one of the best vehicles I've ever owned all things considered, so if you feel the same way about your I4 then I would consider keeping it and just putting up with the issue. Other than that I think you will be very hard pressed to get Toyota to do anything about replacing the piston rings and dealing with the excessive oil consumption unless it's bad enough that it will leave you stranded on the side of a road at any week.
Sorry to be wordy, been down this road in a big way. Hope this helps.
1 - 20 of 22 Posts
