Yeah, I have looked under there for like 45min. No luck. Will need something more to go on.Check the steering wheel column, lower portion.
Thanks! - that seems about right at this point. If anyone else knows something other than "there isn't one" let me know, else I will go with a Techstream solution. (like I said, "very irritating")I don't know about the 07 but the 2011 doesn't have a reset button. They have to be put in with the ID numbers from the tpms sensors with Techstream or some other tool
Trust me, there isn't a reset button. That didn't come until later, like 2010 or 2011.Thanks! - that seems about right at this point. If anyone else knows something other than "there isn't one" let me know, else I will go with a Techstream solution. (like I said, "very irritating")
The '06 (mine) doesn't have one and if the 2011 doesn't either I suspect there is no other answer available for an 07 than, "it doesn't have one."I don't know about the 07 but the 2011 doesn't have a reset button. They have to be put in with the ID numbers from the TPMS sensors with Techstream or some other tool.
BTW, where and at what cost did you have the sensors replaced?Well, I ended up stopping by my local Pep-Boys who reset the TPMS system in a few min for free. Toyota dealer was wanting $150.00 - All is well now.
So do i need to have the tires dismounted?You NEED the numbers to register them with Techstream.
Call the place who put the tires on and see if they can read the I'd numbers. I'm surprised they didn't ask you when you brought them inSo do i need to have the tires dismounted?
When I bought them Denso said they were preprogrammed to Toyota.
"Denso TPMS Sensors are direct plug-and-play with no programming or cloning needed - they're built to the specified vehicle right out of the box. With Denso, installation is a snap - the TPMS Sensor relearns just like an OE part, restoring the vehicle to its original condition. Direct monitoring with real time pressure signal transmission. "
Denso 550-0103 TPMS Sensor
$34.27 Denso 550-0103 TPMS Sensor - Same Day Shipping. Free Returns. PayPal Accepted. Secure Online Ordering. Est. 1969.www.densoproducts.com
