1 - 2 of 2 Posts
Thought my luggage light had burnt out so I bought a new one from Toyota and replaced it. Still no light. Looked online to find a list of which fuses were which. Appears that this light goes through the "dome" light fuse in the engine compartment fusebox according to what I saw online. Checked this fuse but it was fine plus the other interior lights were working and appear to run through this fuse as well. I can't see that the switch is an issue as it is making contact when switched on. What else should I be checking?
The wiring behind the bulb could be loose or broken. Perhaps check the bulb holder with a volt meter to see if you get any voltage.
1 - 2 of 2 Posts
