Hey Guys/Gals,
I ordered a Winjet fog light kit for my base 2010 RAV4 V6 and am attempting to install the parts using OEM harnessing and fuse/relay (see thread titled "How to add Foglights using OEM Wiring on Rav4.3").
I've successfully wired everything up, BUT, I'm not getting enough power from the gray wire (fog light wire pin 4) under the steering column to trip the relay switch. For example, the relay switch is a 12v 40A switch, however the gray wire is only supplying 5v of power.
Does anyone have an explanation/fix to my issue. Very much appreciated!
Cheers,
Cheers,
