2011 RAV4 vibration problem
16K views 4 replies 5 participants last post by  trigama3
Ive recently purchased a 2011 Rav4 2wd i-4. Numerous times now ive had to take the newly purchased car into Toyota to be serviced. The first time i ever brought the car in they balanced the tires & road force balanced them. Claiming the problem had been fixed i brought my car home, & on the way home i noticed the problem yet again. When going between the speeds of 55-60 their is a weird vibration that can be felt. The problem also occurs more frequent when it is cold. The second time the car was serviced Toyota replaced the transmission, admitting the transmission must have been faulty coming out of the factory. Yet again on my way home which is about a 45 min drive that is mostly on the highway, i felt the vibration. For a third time i brought in my car, despite what Toyota was telling me. That "They no longer felt the vibration, & fixed it" They lastly replaced the front Left tire, now claiming it was a bad tire all along.
After the new tire being on, the vibration did seem to ease up a bit... But shortly after it was back to the same vibrations. The driver is not the only person that feels it, sitting in the passenger side & in the rear seats it can be felt. (Not Heard) When feeling it at first, its almost as if you have a low/flat tire.
As of now Toyota claims their is no vibration, atleast not one that they feel.
They claimed to have test drove the car when it was cold, since the vibration can be
felt more easier this way. But yet a 3rd party has to be called in now, & test ride in the vehicle.
If anyone should know or have any suggestions on what the problem may be,
please contact me ASAP. Ive clearly been dealing with this issue awhile &
would like to hear how others may view this issue.
#2 ·
Are the problems over now?
I have exact the same problems, and the only thing what not is renewed is the torque transmission/motor. ( for the Dutch torque = koppelomvormer )
Read on other forums that this must be the just solution.
Our problems are worldwide, known in US, Australia, the Netherlands and France.
Toyota react every time the same.
Please let me know something.
#3 ·
Does it make a whining type noise or just a vibration? My '08 makes a noise and vibrates down the center of the vehicle and just found out that it is the driveshaft or that is what 4 of the mechanics at the Toyota dealers believes it is. T-S-B 0192-10 addresses my issue.
I had a similar problem in a different car I bought new years ago. After MANY trips to the dealer and rotations and balancing, it was never fixed (55-60mph vibration). I found the problem 2 years after the warranty had run out. It was a bad inner (transmission side) CV joint. It was causing the axle shaft to rotate badly, thus the vibration.
Here's what I would do. Have them temporarily replace the tires and wheels from another vehicle and road test. If the problem is still there, have them inspect the inner CV joints.
