Hey everyone just wondering if anyone has had this issue and found the solution.
I have a 11' RAV Limited and my head unit is the 6 CD with JBL.
So my XM is no longer working, it goes from "loading" to "no signal" I've called XM and was on the phone for over an hour, no luck. I disconnected the battery for a couple min, no change. I removed the head unit and checked the XM antenna wire all looked good I even disconnected it and reconnected for good measure, no change.
Does anyone have any thoughts on what should be my next step?
It has happened to me twice over the years. I had to unplug the XM unit behind the glove box and that some how reset it and fixed the problem.
The 2011 head unit has the XM tuner built in--there is no XM unit behind the glove box. ITguy, the only way I can think of to test it would be to connect a different antenna and place it on the roof. I have a 2008 but I installed a 2011 head unit (non JBL) and connected a Toyota satellite antenna (part no. PT546-42070-AK)--it has a proprietary square plug that goes into the blue square jack on the head unit.
