I admit I have neglected service on my car and now need to know what services I need done. I can't find the service guide manual.
I've been doing oil changes. I had my spark plugs and wire replaced and I have had my brakes replaced and a new battery but that is all.
Can anyone post a list of the services I need to do and when?
at that mileage, I would do a couple of drain and refills of the atf, no transmission flushes since if might loosen up crap that will cause problem. also change the coolant, rear diffenrential oil and transfer case if awd
What wire? There are no spark plug wires. You also need to replace the brake fluid. The items folks are listing needs to be done now. Also which engine?
Tires? Tire rotation? Struts? Shocks? All these need to be checked.
