I want to upgrade my RAV4 speakers. Are there any suggestions or pitfalls to avoid?
WHAT I HAVE NOW (vehicle 2012 RAV4 Limited V6 AWD)
- Factory Head Unit marked P10296 on the face-plate. I think this HU was made by Pioneer. All the features on the HU work properly - no complaints. I'm content with my HU, but I'm open to upgrade suggestions. My back-up camera works through the rear-view mirror, and I'm good with that. All my steering wheel controls work.
- 2 factory tweeter speakers mounted high in the front door. From reading, these speakers also include crossovers. There is a 4-wire plug on each speakers (2 inputs from head, 2 outputs to the woofer)
- 2 factory woofer speakers mounted low in the front doors, said to be 6-1/2" speakers, 2 wire.
- 2 factory woofer speakers mounted low in the rear doors, also said to be ~ 6-1/2", 2 wire.
- Is there any other audio component of which I'm unaware?
STEP 1- INITIAL PLAN - 2 NEW FRONT DOOR WOOFERS
At a minimum, I would like to upgrade the 2 factory woofer speakers in the front doors.
STEP 2 - 2 NEW FRONT DOOR TWEETERS
Upgrading the 2 factory tweeter speakers would be good
REAR DOOR WOOFERS
EXTRA WIRING AND ACCESSORIES
Have I missed anything? Thank you, to those who have so bravely gone before me
- Does the HU have enough power to support better speakers without overheating the HU?
- Or, do I need to add in an amp?
- Even if not necessary, would an add-on amp be really beneficial - worth the extra effort? Where would it be mounted?
- Any specific aftermarket woofer speaker recommendations?
- Best 'low power usage' speakers if power is an issue?
- Do I need to add a new crossover(s) if I don't mess with the tweeters?
- That will require new crossovers, right?
- Any after-market tweeter speaker recommendations?
- Any crossover recommendations?
- Should this really be part of STEP 1? That is, upgrade the tweeters at same time as front door woofers?
REAR DOOR WOOFERS
- Are they worth the effort to upgrade?
- If 'yes', any particular speakers that work well in this position?
- Any power issues? Other issues?
- I will probably need 2 speaker mounts for the front door woofers. Any mounts work better than others?
- If new tweeters, can I simply 'gut' the old tweeter mounts and re-use them?
- If rear door speaker upgrades, then I'll need new mounts there, too
- Wire harness for each front door woofer (and maybe rear door woofer). I can solder connections, but I don't mind buying conversion harnesses.
- Is there a wire harness fixer-upper if I keep (or lose) the factory tweeters?
