1 - 11 of 11 Posts
Confused
The cap does NOT turn. It has a post in the middle that matches a hole in the reservoir. It does not turn at all. Does one know how to add coolant to this closed system?
Just twist the cap counterclockwise a little harder. It will make a little click and then turns freely. There is some initial resistance as the 'hole in the middle' is an indentation that keeps the cap from turning unnecessarily.
Maybe it needs to be pushed in first before turning counterclockwise. Simply turning it will keep it locked. ? Some of my caps are this way.
Hmm, possible they 'child-proofed' the 2012 cap?
If I pushed down on mine (2009) while twisting, it would break the indent. It's kind of a cool cap--snugs it up nicely and also prevents over-tightening. Just a little resistance as it clicks to open or close.
Are you sure you shouldn't add coolant to the reservoir tank? Not the main cap.
I'm pretty sure that's what the OP was asking:
> How to remove coolant reservoir cap 2012 rav4 4 cyl?
There is NO cap on the radiator. The cap on the reservoir is pressurized, so make sure the engine is cool before removing it.
Discussion Starter · #10 ·
Thanks all for an answer. When this puppy cools down I will apply your directions. Last thing I wanted to do was break it, my usual action.
Discussion Starter · #11 ·
Indeed needed just a little stronger twist to come off, actually embarrassed how easily it was after doing so. My thanks again.
1 - 11 of 11 Posts
