I don't think he is wanting to add a Camera, he has the backup camera, he is wanting to a a nav system without messing up his backup camera. At least that is what I am reading.You will need to find a way to supply power to the camera. The camera powered by 5v, not 12v like most aftermarket cameras. I would think a hardwire 5v dash cam kit would make the job a lot easier.
I thought he wants to install an aftermarket headunit and keep the stock cameraI don't think he is wanting to add a Camera, he has the backup camera, he is wanting to a a nav system without messing up his backup camera. At least that is what I am reading.
Correct, but the factory radio does not power the camera.I thought he wants to install an aftermarket headunit and keep the stock camera
Correct. However, there is no 6V source behind the radio. The radio itself sources the 6V. What I did is the the radio's Accessory wire which is a 12V source, well above the 2V drop out.You have to be careful with the 7805 since it is rated for 2 volt dropout voltage (2 Volt minimum voltage drop from input to output). Operating from 6V only allows for 1 Volt drop, which may cause stability and regulation problems. There are low drop out voltage versions available.
Be careful. Just because they look the same or fit the same, doesn't mean they're pinned out the same.i found this on youtube, this might help you decide what kenwood model you are lookin for.
https://youtu.be/B66_q4BdKBQ
i dont know about the installation, but the original back of the radio & display receiver assembly looks like this: theres one connector U6 thats dedicated to the television/camera assembly which has male 16pins (back of the assembly). the kenwood model your going to have should have that connection or that something alike to keep
the functionality of your parkview camera.
Unless your steering wheel does NOT have bluetooth control, do NOT use the Axxess ASWC-1. Audio controls on the left side of the steering wheel are retained however, the bluetooth buttons were not "seen" by the module. After a few attempts of reprogramming and reflashing the unit, I contacted tech support and it turns out that the bluetooth control is not able to be seen by the Axxess module. I swapped it out for a PAC-Audio SWI-X and it works perfectly.nrsource19, have you used the crux brand? if so what model year rav4 and trim level? I was thinking Axxess ASWC-1 Steering Wheel Control Adapter.
