1 - 2 of 2 Posts
hello,
I have changed fuel pump at 2013 Toyota RAV4 LE after that it again cranks but not start, fuel pump is working ( I am hearing its sound when I making ignition on). I have checked all fuses and relay - all them is OK. after that I have opened the fuel pipe near the engine and make it observed there is such picture : the fuel doesn't flow when ignition is on then I have made engine cranked but the fuel doesn't flow again but when I have made ignition off and stoped cranking The fuel has appeared...
has anyone had such case ? how can I fix this problem and make it start ?!
Thanks
Nor related to Rav4.4 but general diagnostic tips of "crank/no-start":
1.Read RPM with obd reader to check crankshaft/camshaft position sensor.
2.Spray starting fluid into intake to test for fuel delivery
3.Remove and ground a spark plug to test for spark.
1 - 2 of 2 Posts
