Hi guys
Need help here please. I have a 2014 Toyota rav4 limited. I changed out the battery, and after installing the new battery, the vehicle alarm is activated and won't shut off.I used the remote keys to unlock, lock, and pressed the alarm button but the alarm is still going on......0
2013 RAV4 XLE Plus
I think you just fried your main 120amp alternator fuse and possibly your computer. If it's a constant horn, that happens when you install the battery backwards, with the intention that you disconnect your battery as quickly as possible and look for problems. Good luck in replacing that 120 amp fuse, it's not as simple as just pulling it out and replace with new one. You pretty much have to dismantle the fuse box to undo the small 7 mm hex head bolts that are hidden and holding that fuse, then you can pull out the burnt fuse.
May the force and angels be with you in this one.
