Hi, I've just bought a used 2015 RAV4 XLE fwd, I drove it home today and at night time, I usually like to have the dome light automatically turn on whenever the door opens, so I tried it on the RAV4 today but I notice it won't turn off, even after several minutes. Both the front and center light behaves the same way, both won't turn off after doors are closed. The dashlight indicator works just fine, I've opened each door individually and it turns on/off correctly. The dimmer knob is also set to low. I can turn off the light just fine but I was wondering if I could get the automatic turn-on function working again?
Thank you so much!
What happens when you hit the door lock on the keyfob? Does it turn off then?
