For my last car I had bought a Carista Bluetooth ODB2 connector which connects to an iPhone app and allows you to view/change vehicle settings that normally only the dealer can do. I believe the dealer will ask new owner's at the first service if they want any of these changed? Here's the list of settings available:
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX
Warn when door can't be locked with remote because it's open
*YES* / NO
Warn when sunroof is still open when locking doors
*YES* / NO
Panic function on remote
ENABLED / *DISABLED*
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within?
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
ON / *OFF*
Lock doors when shifting into gear
ON / *OFF*
Unlock doors when shifting into park (P)
ON / *OFF*
Unlock all doors when driver's door is opened
*ON* / OFF
After locking with smart key, allow re-opening within?
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open trunk via smart access button
DISABLED / DOUBLE CLICK / *LONG PRESS*
Instruments / Display / Dings
Engine start indicator
*ON* / OFF
Display odometer after ignition is turned off for?
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Key-in-ignition ding sound
*SLOW* / MEDIUM / FAST
Ding when headlights are left on
*YES* / NO
Seat belt warning ding (driver)
*ENABLED* / DISABLED
Seat belt warning ding (front passenger)
Lane-change turn signal auto-flasher count
OFF / *3 FLASHES* / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
Remote low battery warning
*ON* / OFF
Front parking sensor range
NARROW / *WIDE*
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
YES / *NO*
Parking sensor beep volume
1 / 2 / *3* / 4 / MAX
Activate parking sensors in neutral (N)
*YES* / NO
Enable front parking sensors when in reverse (R)
FRONT / *FRONT CORNER* / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / *OFF*
Dash display mode
*ALL* / UNDISP
Lights
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Automatic High-beam System (AHS)
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after?
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior light control
Heater & A/C
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
A/C ECO mode
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Fan speed reaches its target?
SLOWLY / *NORMALLY* / FAST
Cool list. I have a question about - "Auto-turn on A/C when AUTO button pressed (if needed) *YES* / NO" - I live in CT and obviously it is very cold here right now (Feb). When I turn my heat on via the AUTO button set to 70 the AC light turns on 95% of the time. It makes no sense to me. Can anyone explain this? Another thing I was hoping to see on your list is the silly Roads might be ICY warning once the temp fails to 37. I get that warning multiple times a day and it is not needed. Anyone know how to turn it off?
From what I've learned in the past, AC always comes on in Auto mode, even all winter. It assists in defogging as it removes moisture. My last car which I had for 5 years had it on all the time and I never had a problem.
