Need to find the location of the Flasher Relay & if anyone has experience upgrading this to work with LED turn signal bulbs. I've gone through a number of LED bulbs that claim they don't hyper flash, but all do. LED headlights and brake lights works great but from my reading, it appears I need to find a digital flasher relay. A picture would be fantastic as well as any personal experience in this kind of adventure!
Been discussed before.
thanks ... would be a lot nicer if you could give me a path to that discussion!
2013 RAV4 XLE Plus
Unfortunately there's no relay from 2013 to present, its all in the computer now. I have LEDs on the front, I used Sylvania Zevo, they use quite a bit current plus I have a Switchback halo in each headlight housing. I played with a bunch of resistors and found that an 18 ohm resistor gets rid of the hyper flashing. So i ordered some 18 ohm 25 watt resistors. They don't get hot and the system works perfect but keep in mind that I have the replacement LED and a halo around the headlight projector. I believe the current draw was around 1.85 amps when combined
