When it is daylight the DRL lights come on and do not light the dashboard light. When the sensor senses darkness and the stalk is in DRL the headlight indicator on the dash will then come on as do the headlights.
2016 LE do not have the “auto” feature for the headlights. There are 4 positions on the LE stalk..OFF DRL Parking Lights and ON. If you have the switch in DRL, the low beams will act as your daytime running lights, you have to manually turn on headlights at dusk, hope that helpsWhen it is daylight the DRL lights come on and do not light the dashboard light. When the sensor senses darkness and the stalk is in DRL the headlight indicator on the dash will then come on as do the headlights.
