2016 Rav4 maintenanceh sign reset
My friend has a new 2016 Rav4 and just had maintenance and they did not turn off the Maintenance sign. On earlier models you hold the odometer button and turn the switch but she has a keyless ignition. Anybody know the procedure?
It's essentially the same thing keyed or keyless just instead of twisting you press the button to switch it to "on" but not start the car. Just pushing it briefly without the brake pedal down basically.
From the 16 manual if she has a color monitor it is different, just in the menu:
I had the same problem with resetting it on my 2016 SE a few days ago. I found out the instructions in the manual is not quite accurate. What i did was, in the MID go to settings and find "vehicle settings" (instead of meter settings) to reset the maintenance required message.
