1 - 10 of 10 Posts
2017 RAV 4 SE: My interior light fuse need to be replaced, NO description for any fuse in the manual for inside fuse box under dash and engine compartment.
It should be in fuse box in engine bay, inside of fuse cover has fuse diagram and fuse puller and spare fuses.
Sent from my R1 PLUS using Tapatalk
Most vehicles have the fuse locations on the back of the fuse box cover/panel. I know the Rav has 2 fuse boxes under the hood. If you open the covers, you will find the fuse locations on the back.
From what I understand there are 3 fuse boxes, 2 in the engine compartment , 1 under the dash and no indication for interior lights.
From what you understand, or have you opened up all 3 and looked?
Since it appears you don't want to look, I went and looked. Try drivers side fuse box under hood. There is a dome light fuse I would start with.
Ok, so now which fuse should I buy and how do you take this old one out...?
Hi, I am new here and I hope i am in the right section. I can't find the fuse box in my 2017 Rav4. Question...where is it? and which fuse is best for a dashcam? I need constant power. any information is greatly appreciated. Thanks
1 - 10 of 10 Posts
