I'm confused. Why do you say the SE has a lower front end? Ground clearance is the same as far as i can tell.
Well in that regard, the 2017 and 2016 should be the same for the SE. Either should work.This is what im talking about.
Yes, but here the lenses are amber, and the bulb is clear.In Norway/Europe it's just the blinker lightbulb that's amber, and no sidemarker(caught in a blink in picture below, with the DRL on)
HI @Budoy , how did you resolve this issue?I have tried it, ordered the lower bumper valance (chin) but the lower grille does not fit since i have an LE. And there is a gap on the underside between the valance and the radiator/engine splash shield. Anyone know the part number for this part that fills the gap?
Had to get this part: couldn’t find an aftermarket one so I ordered an OEM part from toyota.HI @Budoy , how did you resolve this issue?
@Budoy Thank you! I'm following your other post, I'll keep you guys posted. I ordered the 4 parts involved in the process. 3 aftermarket and this one OEM.Had to get this part: couldn’t find an aftermarket one so I ordered an OEM part from toyota.
2016 Toyota RAV4 2WD SE (VIN starts with J) Absorber, front bumper, lower - 526180R030 | Toyota, Redlands CA
Absorber, front bumper, lower. 2016 Toyota RAV4 2WD SE (VIN starts with J). Genuine Toyota Part - 526180R030 (52618-0R030, 5261842070). Ships from Toyota, Redlands CAparts.toyotaofredlands.com
The plastic looked really good. I just washed my car and applied dressing on it. The aftermarket parts looks better than the OEM in my opinion. Smoother and with a bit of sheen. The tabs that connect the aftermarket grille and the lower bumper valance to the bumper itself though are a bit loose. I did apply small zipties to each tab to make them really secure. Other than that its on the spot!@Budoy Thank you! I'm following your other post, I'll keep you guys posted. I ordered the 4 parts involved in the process. 3 aftermarket and this one OEM.
I used the same seller than you... How was the quality, any noticeable difference between OEM and Aftermarket ABS plastic quality?
Thanks in advance.
Thank you, @Budoy I really appreciate your support on this project!The plastic looked really good. I just washed my car and applied dressing on it. The aftermarket parts looks better than the OEM in my opinion. Smoother and with a bit of sheen. The tabs that connect the aftermarket grille and the lower bumper valance to the bumper itself though are a bit loose. I did apply small zipties to each tab to make them really secure. Other than that its on the spot!
Have a photo from the side?Hello team, here the results of the conversion of my RAV4 2018 LE (VIN starts with 2 = Canada)
I used the same parts as @Budoy , but in my case I went with the two tones lower valance. Thanks once again for your support!
Parts involved:
1. Fits 2016-2018 Toyota Rav4 SE Grille Front Bumper Grill Center W Hole Honeycomb
2. Fits 2016-2018 Toyota Rav4 SE Grille Front Lower Grille W Tow Covers Honeycomb
3. For 2016-2018 Toyota Rav4 SE Front Bumper Lower Valance Cover W Molding Silver
4. OEM TOYOTA RAV4 ABSORBER FRONT BUMPER LOWER 526180R030
View attachment 166379 View attachment 166378
