Had a local garage put on steel winter rims the other day. Car had Alloy rims for the summer. Had to buy another set of lugnuts to fit the steel rims. My question is (see picture), should the middle be exposed like it is, the brass looking center? Will that not rust? Thanks
Thanks
A center cap that snaps over the hub flange would be the best way to prevent rust, which will happen. Your garage or tire dealer should be able to help. If you can't find a center cap, keep the hubs coated with Fluid Film or similar protective lubricant.
Honestly in most aspects, with your other wheels on, those aren't exactly sealed let alone hermetically from any moisture to begin with. BUT.. usually back in the day there was a cap that would encapsulate that, usually had bearing grease in it. I would think not much has changed, and at least if its only FWD or would also apply in an AWD scenario. there should be whats called a "Bearing cap" over that, its flange'd, and whether the alloy or steel wheels on, they also will clamp down to keep that pressure fitting cap from coming off as an added precaution.
I would honestly take it to the dealer, talk to your service advisor and have him do the legwork to either get you some part numbers for the OEM parts to order them or disclose/explain why they aren't needed.They may also be silver or zinc [yellowish] coated new. May have to paint them black rather than look like an LAPD patrol car.
In addition, the only thing that would possibly rust after some time is the black 12 sided nut on there. everything else is zinc plated = no rust
Also, if you have a few extra dollars to throw away and burn, LOL.. hit up a local auto parts store, ask for a set of beauty rings. They'll add a 1.5"-2" polished lip to the inside the outside edge and actually dress them up a little bit without going all out and or looking like you had your wheels stolen. lol
Some like it, some don't.. I had a 1st Gen Toyota bB when they first came out used as a business customer shuttle vehicle. The hubcaps looked awful and were tossed - FAR!, rims weren't in the budget just yet but on a white bodied bB, it looked like a whirlpool washer on its back so I shot the OE steelies in a sweet bronze finish, wrapped in what was the first generation of Falken Azenis RT615's [205/50/15] and got a lot of compliments and then wait for it -- showed them they weren't real rims..! #doubletakes ; )
Wow that pic brings back some fun memories... geez
