21 - 40 of 66 Posts
Fair, but there's also a fair bit of "what the heck?" in engineering decisions. To the extent that they tied the DCM directly to one of the audio channels for fault-tolerance when the 12v system fails is smart. But to that same extent... if the DCM ever fries, I lose audio just because it's a passthrough? That feels pretty silly.
C'est la vie. The bad guys' data mining wins again...
Discussion Starter · #23 ·
I did not notice the right front speakers going silent but verified that happened after killing the DCM. I am back working on this issue and found some wiring information in another thread that shows the connectors to the DCM (Budget aftermarket stereo retrofit for 6 speaker RAV4 (Pioneer head unit)). I have had my DCM out of the car previously and can pop it out without much fuss to wire the speakers to function. There is a 4 pin connector (G133) that seems to need pins 1 to 3 and 2 to 4 connected to bypass the DCM. I plan on leaving the connector off the DCM but jumping these pins in the wiring harness. I'll post an update when I confirm this works (I hope!).
🇨🇦 2020 RAV4 XLE Hybrid - Super White
So curious question, my car is a Canadian '20 XLEh with a 7" touch screen. As far as I can tell I don't have DCM on my car, wondering if this is a premium feature on the larger screens.
Not that I'm complaining, but the auto time update sounds nice because my clock losses a minute monthly. I went into the hidden service menu and other users have values there and data in the GPS field - my signal and GPS field is blank, and I have no icon with DCM in the home screen.
· Premium Member
I always thought Safety Connect (SOS) service was provided through the DCM, if so it may have one, it's just not shown on the display, or there's another device that provides the cellular connection, or it uses your phone?
That makes total sense, and you're probably right that SOS is provided through DCM.
No SOS Doomsday launch trigger on my map console, and as far as I can tell digging in the menu's WITH my iPhone connected outside with full signal strength, the car isn't emitting or receiving any signal in the hidden service menu.
2019 Rav4h Ltd 🇯🇵
Doesnt the DCM "require" replacement after 3 years? I wonder if it will behave the same as ganking it from the system? If so many people, including me, are expecting to just "pass" on replacement and move along. I really hope Toyota isnt making that a required replacement.
· Premium Member
The Sep 2018 pricing document is the only place I've seen a service and labor charge listed for Dynamic Nav and the Rav4 isn't listed, the 2020 document doesn't list anything related other than Destination Assist.
Discussion Starter · #29 ·
As I understand it, from when I bought my 2019 LE Hybrid, the Entune, driving behavior recording and SOS features were free for three years and after that you had to pay for it. I don't think the DCM unit needs replacing - just the account that pays for it. I disabled my DCM and don't miss it at all. I have made it through driving in the U.S. for 50 years and was able to get through any breakdown or accident without shouting Mayday!
2019 Rav4h Ltd 🇯🇵
I dont care about the SOS. Wife doesnt like the Nav and uses her Pixel. I hate the data scraping.
You pulled the device but left the fuse? There was a report in this thread that pulling the fuse cause radio issues and other problems.
thefranchise713 said:
When I turned the car back on, I knew the audio immediately sounded weird. So I pushed the balance in the audio settings to full front right. Sure enough, this is where my audio went completely absent. Restored the fuse, and my audio came back as well.
Discussion Starter · #32 ·
Colonel,
See my update #23 above that I hope will fix the right speaker issue. I have not yet gotten around to the speaker rewire at the DCM but will post results when it's complete. FYI the DCM is pretty easy to get to, although you would not know it by looking at the dash in front of where it resides behind the HVAC controls.
2019 Rav4h Ltd 🇯🇵
Colonel,
Yeah...popping it out doesnt bother me. Losing the radio functions does. Ill eagerly await the feedback of your 1-3 and 2-4 bypass test.
FWIW: Restoring RH audio with DCM disconnected could be accomplished by jumpering between pins 2&5 and 3&6 of G9 DCM connector...
Hello guys, I own a toyota rav4 xle hybrid 2020, I bought it from Canada, I live in Iraq, dcm does not work. Can I change the service to the networks in my country? Is there a SIM card that I can change
No sim...you need a DCM programmed for your region. At least there is a simple solution for those feeling the need to deactivate DCM...just move overseas!;)
21 - 40 of 66 Posts
