1 - 8 of 8 Posts
Hi friends,
I just purchased a 2019 RAV4 Premium with halogen fog lights. I know that there is an upgrade for the LED bulbs from Toyota when the car is purchased new, however, I purchased the car used. I am looking to switch the halogen bulbs with official Toyota LED fog light bulbs.
Does anyone know how easy this will be or have any knowledge of the replacement? Is it a simple bulb change or does the housing need to be completely switched out?
I am attaching a picture of the LED fog light from the official Toyota parts website for reference.
158330
Thanks in advance!
2019 XSE
I may do the same. here is a thread of others who have done it.
Hi friends,
Thanks in advance!
My 19 was easy to switch, google for videos, (
), this was the first choice, I didn't watch, there were several, as there are several ways to make a simple act difficult, ymmv.
2020 RAV4 HYBRID LIMITED
Hi friends,
Thanks in advance!
Just swapped my OEM LED fog lamps for Diode Dynamics. If you're interested in buying mine just message me.
As for the install the housing needs to be swapped out. It's a fairly simple process. Remove two screws & two clips on the splash shield to gain access to the area. Fog lamps are screwed in with one screw on each side. Passenger side is harder because there's less room to work. This video will show you what I mean.
2021 RAV4 Prime SE
How do you like the diode dynamics? Did you get the full 4 bulb lamps or just the replacement single bulbs?
1 - 8 of 8 Posts
